just double check you dont have a vacum leak around the intake system easy way to test spray contact brake cleaner around intake boot/ throttle body at idle and should be able to hear the idle change when spraying if it has a leak good staring point
Idle control valves don't last forever. However I've noticed using different hardware and a lock washer was a fix for me for a tighter seal. My wife's went bad in 3 years with only 15 miles om it when I bought it.
