i recently tore a rear tire and have decided to go with bigger tires.
i bought a new set of rear wheels Traxion 12HDX11 4/110 bolt pattern and a 2x5 offset, i read somewhere that was the correct offset but now i see thats for the SRA models
Question is will these rims fit with 27x10x12 Maxxis Bighorn or should i get the proper 4x3 offset
If I'm reading your numbers right you got a set of 11 inch wheels and you are wanting to put a set of 12 inch tires on them. That's not going to work. As far as the offset they are going to make the back of the atv wider and the tires are going to stick outside the fenders.
The new traxion wheels are 12 inch, so the tires will fit the rims. Was wondering about the offset as the stock rims are 4+3. I pretty sure it will work but I will have a wider stance and my tires will stick out past my fenders
Sent from my SM-G955W using Tapatalk
