I have no lights at the display at all but the headlights work. I have replaced the battery, checked fuses and connections. I jumped the solenoid and the the display would light up but would not start. Could the ignition switch be bad even if the headlights work. What the ecm.
Did you find the problem mine is doing the same thing
Check the connections between the display and ECM. Make sure that they are all clean and tight.
