New to the forum and had a question about rim fitment on my fm1 500 foreman. I wanna get some sti hd beadlocks but everything i find is 12x7...evey site says no fit for my bike! So guess what im after is will the 12x7 fit on all four corners of a 2016 solid rear axle?
a 12x7 will work, as long as you have the correct back spacing and lug bolt pattern
the problem is NO after market company period, makes exact wheel back spacing as OEM
they all will stick out farther and get you more dirty as you travel LOL
I am sure others here will give you better info than me, I run stock wheels> simple ,
as I gave up on being pretty/llooks or ?? a long time ago,
these days I just want wheels that hold tires and air, care less about looks! HAHA!
Was curious cause i have a 92? 300 i wanted to put my 2016 500 stock rims with 27? mudbugs on and put new rims n tires on my newer bike...
Your stock 2016 rims will bolt right on and have the correct offset on the old 92.
For new rims for your 2016, what you're looking for is a 5+2 offset for the front, and a 2+5 offset for the rear rims. But what you'll find is the 5+2 are much more available, because of so many machines these days being IRS. So what some guys do is buy all 4 rims at 5+2, and then run 2.5 or 3" wheel spacers on each side of the rear axle. Then you can run any set of rims that were meant for an IRS machine (with 4/110 bolt pattern).
