The left rear wheel bearing went out on my brother in laws 420 rancher. Can I unscrew the 4 bolts that hold the left housing, rear differential and part of the frame and twist the housing ninety degrees left or righ to slide the housing off or is it an easier way to remove the part of the bearing that is in the housing. I removed the seal, inner part of the bearing that is on the axle and ball bearing bu can’t seem to get to the race of the bearing to remove it. It a 420fm1g. Thanks,
Stephen
Stephen
