Hello all. I have a 2015 Honda Rancher TRX420FA6. I purchased it at a good price but it was definitely in an accident. The plastics don't line up well but it rides straight. When I got it the power steering light was on and it did not work. I did the reset procedure and it worked perfectly. Then I hit a rock with the tire pretty hard and the light came back on and P.S went out on me. I reset it , it works until I hit a rock again or there is a heavy load on the front end and I try to steer.
Any ideas where I should start? I want to fix it for good.
Have you followed all fault diagnosis from the FSM yet?
I have read that people get a "23" code on the check engine light and the maintenance light. Mine is flashing on the PS light. Does that mean anything? I can't seem to get a service manual to download. Should I just buy one?
There is a replacement fuse in with your manual, the fuse is located by the battery in the grey case
If It had a bad fuse. It wouldn't work at all correct? I can reset it and it works until the steering encounters too much resistance. Then the PS light comes on , power steering stops working. I need some ideas..
