do you get any Gains from a programmer without exhaust? What's the best programmer to plug and play without needing a dyno? And does anyone have a recommendation for slip on exhaust that's not loud but still has decent flow?
The only reason you need a programmer for is to omit the O2 sensor.do you get any Gains from a programmer without exhaust? What's the best programmer to plug and play without needing a dyno? And does anyone have a recommendation for slip on exhaust that's not loud but still has decent flow?
A functioning O2 sensor monitors your emissions and alerts you to problems such as rich, etc. The actual problem when it goes off then needs to be traced down to the actual cause.Which just helps with it running to rich or to lean correct?
Hers tops out about 45-46 now with 26's on it, so the slightly bigger tires will throw off the speedometer a bit. With the gear reduction I did have to buy an autoshift module from Rapid Revolutions so it would shift correctly in auto mode at WOT.How much top end speed did you lose with the 18%? I have been looking into the 500 top end but wasn't sure what all is necessary for the install?
I actually lucked out, bought a set of nuts and bolts from Powersportsnation (when they strip a bike, they dump all the nuts, bolts, and odds and ends in a bag, and sell it on ebay). The nut and bolt setup came with the FM secondary.So you just ordered the factory footshift primary and secondary? For the same year? And do you remember close to what you paid for it?
This mod seems cheap and easy. Just my kind of mod! LOL Please explain as best you can how the power is better. More low, mid, top. etc....thanksDepends on how much $$ you have to spend with the programmer. (IMO)....
The only way to know for sure is to get one & keep an eye on your spark plug. Unless you have done it before, you really dont know. I use resistors to trick the ECU into thinking its running leaner than normal so it richens the mixture up. No problems doing this for well over 1000 miles. But its not for everyone.
Its more bottom end than anything. Machines run lean from the factory because of emissions but for the amount of difference i am not going to worry about it. Lets just say, if you try & pop a wheelie with one in 1st its almost impossible. But once i did this mod I can (with a bounce) bring it up in 3rd. So it does make a difference.This mod seems cheap and easy. Just my kind of mod! LOL Please explain as best you can how the power is better. More low, mid, top. etc....thanksDepends on how much $$ you have to spend with the programmer. (IMO)....
