Hi everybody I’m new here, I am from Uk I love reading your discussions on here I think there brilliant. Right my first post. I have got a 2015 Honda trx 500 fm1e the problem I have is it is stuck in 4wd tried a few things push the disengage button and switch off and on etc. Nothing seems to work and also when I try to put front differential locks on the light just flashes I think it’s supposed to stay on when it’s engaged. Do you think I should buy a new switch assy or is there a way I can test if it’s working or not? I’m not the best mechanic but will have a go at anything. Just so that you know I have checked for any moisture or corrosion on all of my plugs & diodes under the seat and all look like new. And have today done full oil change engine & both diffs
Thank you so much for reading this post and thank you very much in advance for my miracle answer ?
