Good to know on the wire plugs.An older motor will not work on a 2015. The wire plugs and electronics ecu fuel pump and such are all different and so is the flywheel. The 16 back cover will not fit an older engine case half even if you carry all that stuff over.
A new engine is a couple thousand dollars when you probably need a $600 repair at a shop... or the fellas here can help you.
now, I know us southern folks are a tad slow ?, but come on, he's in Alaska !!, even I seen this in his screen name...lmfaooo..Ok got it I see now your user name says alaska lol
We can absolutely walk you through it. It's not very hard but is there anyway you can post a video so we can hear the noise just to be sure of what it needs?
hehe.....( evil grin ).Lmao!! ...Ima kick you in the shin shade!
Hello. Did you find an answer to the engine swap ? I’ve got 2012 trx 420 fm. Have chance of 2015 420 fm. And wiring harness. Has the 2012 engine connections are different. Wondered if anyone can helpHi new here , question is are all 420 rancher engines the same. Can I put say a 420 engine on a 2007 onto a 2015
well I would say the it depends on like what type of fuel system you haveHi new here , question is are all 420 rancher engines the same. Can I put say a 420 engine on a 2007 onto a 2015
