Hey folks, I am new to the forum but it looks as though this is a good place to gather some advice. I have two Foreman Rubicon 500 4x4 atvs and they are both having the same issue. when we run for an hour or so and then turn the machine off it will not turn back on. when you turn the key it does not show that it is in neutral or in gear just the bar across. both of the atvs run well once they are started and there is not any lights on.
If you all have any ideas i would appreciate the help.
Are you turning it off in gear?
^ This ^
X3 are you turning it off in gear? As stated, what transmission do you have Foot shift, Electric shift, DCT? When you get the --, try rocking the atv with the key on. It should go into N or D. And then start it.
Hold the right brake and start it...When it is running it will show what gear it is in...
