1 - 1 of 1 Posts
My 2014 680 Rincon has been a great machine until recently. After running normally for awhile, it was up to temp, it quit idling. It would start and die with out giving it a little throttle. I parked it over night to see if it would act the same way cold, and it did. I did a new fuel filter, air filter, and plug (unfortunately I did look closely at the new plug, its hotter then what honda recommends) Tank screen was clogged up so it's gone and placed a in-line filter between tank and pump canister. Also pulled the IAC valve, seems good, its working.
I also have had the valves adjusted, pulled the head, checked valves heads/seats, cam lobes.
Still starts and will not idle.
What gives?
1 - 1 of 1 Posts
