I have looked a numerous posts for Rancher shifting issues but I believe I have a different problem. When shifting into reverse it seems that it does not go into gear, however, if I rev it up, it will actually take hold and go. It does this in 1st also but not nearly as bad as reverse. Once in gear it performs as it should with no slipping, even with a load or resistance such as climbing steep hills. My first thought was a clutch issue but if that were the case, why doesn't it slip under load. Anyone else experience this and how was it corrected?
