it went from running normal to having this problem from one evening to the next morning.
it starts like normal and dies after a few seconds. you have to turn the key off and back on to start back again but it will never run more than a few seconds. put a spark tester and the spark stops causing the atv to die. changed the ignition coil and computer module made sure the kill switch was working properly. took it to the local dealer and they said it needed a new fuel pump(which didn't fix the problem) and now they are saying the cam lobes are worn down and needs a new cam. That explanation didn't make any since so i brought it back home before they screwed me for over 1,000$
What else should i try?
