I am having problems with my fourwheeler leaking oil out of the oil overflow near the water pump and checked the dipstick which was also way high. No I didn’t overflow it when it was changed last which was last fall. I drained the oil and went to add oil in the fill plug and noticed that near where the water pump bolts on it looks like the case is missing a chunk of metal like right where you add oil?? Is this normal or not. Is there a port for where the water pump comes in or is it actually missing a piece of the case. Thanks
