hello all, 1st time on this forum 1st time ive had problems that i need help with.
2014 ES rancher 420 has no display and will not start or even crank over. no lights no nothing. battery is good and charged and even had a charger on it while trying. fuses are good i checked voltage on both sides of the fuse. i pulled the panels off on the sides and front to see if mice chewed through any wires and found all looked good. is there a specific wire (color of wire ) i need to look for? the box that sets on top of fuel tank the has wires plugged into it ( i suspect thats the computer ) could it be bad? any help would be great. i think i thought of everything i did but if need more info please ask.
thanks
you should use a 12 volt dc test light to see if power is reaching the ignition switch ?. and check to see if power is coming out of ignition switch ?.
thanks
what ended up being the problem mine is doing the same thing, I’m thinking ignition switch.
