Hello, I recently picked up a used 2013 TRX400X and I noticed the right side front wheel is leaning inward more so than the left front. I inspected the front end and everything looks ok... it even has the paint marks on all the nuts from the factory. This quad is in very good condition I don’t think it’s been tweaked and I don’t think anything has been messed with. But I know there isn’t a camber adjustment on these. Has anyone ever seen anything like this. The only thing I can think of is the knuckle has bent slightly somehow. The hub and bearing is tight no play. Has anyone ran into this and is there anything you reccomend checking? Or should I just not worry about it and ride it.
Completely normal. When the frame was welded there jig was slightly off. I have personally seen over 20 that were this way right out of the box. Aftermarket a-arms give you camber adsjustment that can make up for it. But you wont notice anything weird about the handling as it is. Welcome to the forums!
Reactions: retro
