Hey all, new to the forum, I run a small Power Sports repair shop in Ossian, Iowa. Any help finding a manual download? Got a 2013 Rubicon showing trouble code 4, which in my reading is gear position sensor, tested against a section of manual i had saved, showed no good. New switch came in today, installed, same code, 4 quick blinks of --, then one long --, trouble code 4 correct? Its in fail safe mode, will not shift or display gear position on indicator, however the N and R light up when in corresponding transmission position. Thanks
