I think my petcock valve on my 2013 Rancher 420 is clogged. Will not run on the On setting but runs fine on the Reserve setting. I am wondering how to remove the petcock and clean or if not necessary to remove, how to clean. Thanks in advance!
#4 on this print is the tank screen , after removing the petcock ,you can carefully use a pick and some needle nose pliers and pull it out the tank ---but I would bet the clog is in the petcock it's self -------- hope for the best if you take out the screws that go thru the petcock into the nuts which are molded into the plastic and some times spin in the plastic
https://www.partzilla.com/catalog/honda/atv/2013/trx420tm-ac-rancher/fuel-tank
