I have a 2013 Rancher, it will not start, it has fuel to the injector, but I dont believe enough pressure, it will start off carb cleaner sprayed in throttle body, I removed pump, changed filter and cleaned out the inside of pump bowl, extremely dirty, still no change. I am asking if many of you have had injector issues or am I needing a fuel pump, I know the volume and pressure of fuel flow at 52psi in a car, and this pump produces the same pressure, I'm not getting near that. and other ideas will be appreciated!!!! snow storm coming and I need my plow!!!
