Had a plow on moving some dirt around when I hit a stump then I noticed the speedometer was going haywire and then totally disappeared also when in auto mode it will not shift up but works fine and the electric shift mode any suggestions been messing around for a while can't figure it out
where's that subzero member when you need him to see how well es models really are compared to manual shift models ??!!!!..lmfao. i stand my ground..es models are junk !. anywayyyy..check all your connections to speed sensors located on and around the front diff and rear output shaft, make sure they are tight and clean ?!. also, the battery must be fully charged for es models to work correctly !.
