Left key on. Battery dead at 0330 AM. Hooked up jumper cables to battery. Hooked them up backwards. Blew fuse. Replaced fuse.
Since then
Starts up normally. Idle is fine. When you put it in gear it might go 5 feet or 50 feet then engine and heat light both come on and it dies. It might not do any of that at all and keep running. I did find what I thought was a starter switch that was not in its rubber boot in front of the battery. Put it back in its rubber holder and still same problem. Any ideas?
Since then
