Saturday I used it to pull a trailer around front. When going to crank it back up t It will turn over but wont start. I have changed spark plug, I verified gas is coming from the fuel pump to the injector. If i put gas in spark plug hole or intake it will run for a second or 2. I did have rats chew the wires that go to the angle sensor and the ignition wires back by the battery(about a year ago). I have repaired all the wires I find and there is no longer any check engine lights blinking. It has been running since the wire repair. I'm out of any idea of what it can be except for possibly a clogged injector. Is there any other wires I should check that may run the fuel injection? I have looked over it several times and don't see anything chewed up. The atv only has 211 miles on it. Any help or ideas would be great.
