Hello all, new member here. I have just purchased a 2013 Foreman TRX500FMD footshift with fuel injection. Trying to get it to run. I can spray air filter with starting fluid, very limited times, and she'll run that out and die. I have fuel flowing to fuel pump and the pump runs for only several seconds when the key is turned on. I unhooked the fuel line at injector (throttle body) and noticed gas would come out during this cycle time of the fuel pump then stop. It did not appear to have a lot of pressure/flow and only lasted 5/10 seconds.
My question is, is the pump supposed to keep running until it builds pressure? The pump only runs for a few seconds with or without the fuel line attached at the injector. I was going to check the injector for spray but had difficulty removing the mounting bolts. I was hoping someone has been through same issue before and could lead me in the right direction.
Thanks
Thanks
