2011 Rancher with a small hay wagon and 2 bales of hay, going up a slight incline, asphalt driveway with a little snow. Starts bucking in 2 Wheel Drive. Shift to 4 Wheel Drive and the bucking continues. Drop the trailer and it still has problems. Some where I read that one of the many Honda's has an adjustment for the clutch. Can't remember which one and can't find any mention in the Service Manual. Manual talks about oil pressure at a port that should be 74-78#'s. I shut the key off and tried it again and didn't seem to have any issues, but I didn't have the trailer on it, just plowing snow up the hill. NO Fault codes, but thought that maybe the drive shaft coupling might be spinning. Then remembered about a clutch adjustment. Book talks about oil pressure and thought about not wanting to go into 4 Wheel Drive. Also thought about speed sensors and Throttle Position sensor, but again I wasn't getting any Fault Codes.
Any body have any Ideas? Full Charged Battery. 3/4 full of new fuel, oil level good.
