I have a electrical issue with my headlights and would like to have more experienced input, I have a 2011 Honda rancher with 500 miles on it and the headlights are acting up, here’s how. My lights are always on when I turn the key on regardless of the position of the yellow on/off switch. When I turn the yellow switch to the on position it turns on the cluster light and hi-beams if the upper switch is in low beam, if I changer the upper switch to go-beam it turns the lights to low beam, another issue with it is if the yellow switch is in the “off position” and I turn on the low beams with the upper switch the dash lights will then come on. If I could please have some help, please and thank you
