2010 Rancher ES
I have a 2010 rancher Fourtrax, efi eps es, all the electrical crap, parked it for a week, and went to start it, and it just cranks away with a blinking (-). I have replaced the Gear Position sensor, fuel pump relay, cleaned the es motor, cleaned most of the connectors, and re soldered all the ignition switch wires and yes i have checked the fuses. I might be missing few things there but its been awhile. But the coil isnt firing, does have voltage at the coil, and the fuel pump isnt switching on. The PS light is flashing some codes.
Video Here-->
. If anyone has some ideas please let me know. Im about over this, i have at least 20 hours in troubleshooting in this f'ing thing...
you will find better, smarter help here ---> www.atvhonda.com , member owned !. if you decide to join there ?, please post a thread in the new member section , tell us about yourself a tad !. ( yes..i am there as well ! ).
2010 Rancher ES
Discussion Starter #3
Video Here--> Cant post first post. If anyone has some ideas please let me know. Im about over this, i have at least 20 hours in troubleshooting in this f'ing thing.
2010 Rancher ES
Discussion Starter #4
Edit, there are no dtcs now. Just the flashing (-). Still has all the same symptoms though. Something changed in the last 2 years
that line --> -- , when flashing..tells you the trouble code !.
2010 Rancher ES
Discussion Starter #6
There is no longer a pattern to it, it just blinks once every sec or so now, no variation. The only light that has ever flashed a pattern was the ps light, there is a video in the first line. 14, 31, 32, 24 were the codes if I got that right. But I let it sit for three years and now there is no pattern to anything. Do I need to make a jumper to put it in read mode? I remeber doing that before I think, got that out of the service manual. Sorry about the rambling, I am a bit tired. I can record a new video if I need. My guess is a bad computer at this point..
sorry, i'm not much for that model, atvhonda.com is where the very smart guys are at, and your already there I think, ask there please. I only come back here cuz I am a mod here.
