was riding and running great, went over a ant hill and it immediately died and wouldnt start again. i turned off key then back on to reset angle sensor but still wont start after several failed attempts. Any ideas?
Start with the first easiest issue. Did you accidentally jar the kill switch? Flip it back and forth a few times to be sure it's in the run position.
when you say won't start, do you have spark?
is fuel good and tank clean, and reason asking is, if you go up or down a steep hill you can shift fuel in tank and get water into system if there is any in tank, same with crap inside tank
is this a carb'd or EFI machine?
have you checked all fuses to make sure all are good?
more you tell us, better we can help you
About this Discussion
3 Participants
mrbb
Honda ATV Forum
Full Forum Listing
