Our Big Red was running fine then suddenly will not run. Step on the break and turn the key it won’t roll over it clicks but won’t turn over .The battery appears to be good and we just can’t figure out where to even begin to look. Thanks for any help
the clicking noise is usally coming from the starter relay most licky a dead bad battery batterys can have voltage but low on amps only way to tell is use a load tester on the battery a quick test is to boost the machine off a good battery. always check battery conections to make sure they are clean and tight.
Mine quit doing what it was doing and started acting some what fine. Still had a drag when starting. Yesterday it just would not start. I put a new battery in it and still just clicks when turning the key. Honda is ordering me a starter solenoid, maybe that will fix the issue. Will keep you posted
