Hello! New to the forum here and happy to have found this. I have my brother's '10 TRX420FE 4x4 ES with no/intermittent power. It was being ridden and stopped running abruptly (temp and mil lights came on). Bike was restarted but ran only briefly before quitting again. Key was cycled and when turned back on there was no power to the display.... anywhere... no click at the solenoid... no blown fuses... nothing.. nada... zip... zilch. I was able to get the display, Neutral, Temp and MIL to light up after disconnecting the Engine Stop/Fuel Pump Relay (WPC 8P) however start button still dead. Having the relay plugged in and turning on headlight switch resulted in high pitch whine/buzz from relay. Also, with headlights disconnected turning on light switch turns on display backlight, no backlight with headlights plugged in. I have checked every connector for corrosion and solid seating, have checked battery and fuses. I have full power from battery at main 1 but only 3.7v at main 2. I got a new Engine Stop/Fuel Pump relay, installed it today and result was intermittent power to the display, singing/whining relay, pushing start button or crossing starter solenoid posts stops whining and blanks out display. I am at a loss... even having the relay powered directly from the battery to check continuity of the relay will cut power to the display, disconnect from the battery and display lights back up steady on.
Was reading a reply from a technician the other day on one of those "Ask" sites and he mentioned something to do with the light switch on the left handlebar but never completed the thought or information to the inquirer.
Any ideas?? All grounds are solid, contacts clean, battery posts clean, ran the entire loom (in original condition w/o splices or add on wiring) and no rubs or cuts - despite that the symptoms appear to be an intermittent connection. Appreciate any feed back.
BTW a huge thanks to Bryan K. for the FSM link. Was able to get a legible schematic finally. :grin:nerd
