so ive got a 1984 200x im going to put in a 200s motor but first i want to rebuild the 200s motor how should i go about it bigger cam, wisco piston, bore whats your take ive never done this before and just want to make sure it will pull my 300 lbs around this is my first trike and want to do it right..
Any boring less than .040 really isn't doing much but definitely switch to a high compression piston 10:1 or 11:1 should work just fine, also I would look into a different carb set-up like a flatside, put on a good exhaust system HMF, FMF, Curtis Sparks, Two Brothers Racing are just a few top brands. Don't forget the air filter, Uni or K&N. if you change out the cam I wouldn't go any larger than a stage 1 unless you have the money to blow. I would most definitely invest in a new timing chain and timing chain guide your already there save yourself the headache later. replace the clutches too. the 200s is an automatic or sportclutch the 200X has a clutch you do know that right?? Good luck post some pics up let's see what your working on.
i know about the clutch on the 200x it currently has a 185 motor in it ,the guy i bought it from told me he had the 200x motor that i could have with it it just has an exsust stud snaped off so i said no problem and i took it in a box and did not know diffrent , to only find out its not a 200x motor but a 200 s motor so while i beat up the 185 motor im gona rebuild the 200s and
from 79-85 the 200X carried the same camshft as the 185s 79-85 , so I can only assume the 200S carries the same as well.... check Web Cam Inc. - Performance and Racing Camshafts if you have any questions just give them a call. Your looking around 200 bucks for that camshaft. Wiseco piston for a 1985 200S ...Part Number-4156M06700 $154.92 67.00mm 2.00mm Compression Ratio - Actual: 10.25:1
Displacement: 204cc
Stroke: 57.80mm Here is the Piston kit complete rings gaskets, Piston,Wrist pin and pin locks.....
Wiseco Part#: PK1004
Product Type: Piston Kits
Description: Honda 185,200 ATC (4156M) 67.0mm
2638XC - 67.00 MM RING SET
4156M06700 - HON XR185,200, ATC 185,200 2638XC
CW15 - ROUND WIRE PIN LOCKS 15MM (PAIR)
S522 - PIN-15MM X 2.2047"-CHROMED PLATED
W5056 - GASKET KIT-HONDA ATC 185/200 81-86 67mm
$198.86
Also a good upgrade woud be Exhaust you may have to fabricate something from a slip-on muffler like HMF or FMF
