I have a 2009 Honda Rincon. Recently it was high centered on a downed smaller tree. After getting it off I noticed that none of the lights worked front or rear and the radiator fan stopped working. Everything previously worked before getting stuck.
I did some trouble shooting and found that the fuse block is not getting power for the fan and lights fuses. Go figure. The question is is it possible that something shorted out in the fuse block or more likely that's a wire or connector was pulled loose. A buddy and myself have crawled over and under the bike trying to find a loose wire, ground, connector etc. but have had no luck.
Has anyone ever delt with this before?
Thanks for any and all help
