was riding yesterday and switched to 4wheel drive. no luck. brought it home and realized the front driveshaft was the issue. I pulled the bolts out of the diff and pulled it forward to release the shaft. turns out the teeth of the driveshaft comming out of the engine are rounded quiet bad. see attached pics. i am wondering if this pulls out of the engine or do i have to split the case and take it out. thank you for reading. im hoping for the best. i dont have alot of experience when it comes to cracking the engine so i would like to avoid this if possible.
Hi: Just give a good hard pull it should come right out.
Hi: Yes it will pull right out -- there is a o-ring on the spline shaft -- make sure the bike is not moving when you are trying to pull it out.
hi. ya iv been pulling on it like hell. doesnt seem to want to budge. any more tips on this?
Hi: Sorry I was thinking of a other bike -- you need to take it apart -- if you can weld it go for it --nothing to loose.
