I'm having an issue switching gears. It's stuck in 1st gear and it looks like the shaft the shifter sits on is coming out. The shaft has a lot of wiggle room and it's very loose. Any suggestions?
Welcome to the forums! Lots of great folks here that can help you... you'll need a copy of the FSM to refer to as you work. Get yours HERE before proceeding and read up on it. Have fun!
welcome to the forums. chances are ?, your shifting shaft needs replacing ?. without having my hands on it ?, I can't say 100% this is your problem ?. there is no way of knowing for sure , until you did deeper into the motor .
Yep, if the shifter is able to be moved around then I would guess the shift shaft is broken, and sounds like it would be at the back. You'll have to pull the rear cover off to see. If it is broken, you'll have to pull the front cover as well to put a new shift shaft in.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
