Thanks people for making forums like these what they are.
New member.. probably a common problem, but...
I took my son and his rancher to an old sand pit.. there's wonderful trails and hills and whatnot.. He barely was able to get back down from the hills after 5 minutes with a terrible knock with the engine not wanting to run. I thought the worst.. like "did you run it out of oil??".. Oil seemed fine, coolant was fine.. but now.. suddenly, it runs rough and clanks something fierce! We parked it and planned on having to do a rebuild.
Last night we pulled into the garage bay and pulled the head. I grabbed a hold of the piston and connecting rod, and everything is beautiful.. the piston and rings look great, the wrist pin and connecting rod has no play (except the slightest expected side to side rock. The piston, rings, pushrod all look almost like I opened up a brand new engine.
Before this, we did a valve adjustment just to be sure we didn't have any play there. It didn't need much to get back to exact specs, and certainly not enough out to be "out of spec". The valve seats and how the valves are seated look nice, there is no marks of valve contact with the piston, so I can't figure what else this racket is coming from. I didn't expect the valve adjustment to take care of this, because it's just too loud to be valve noise. It sounds to me like an engine knock.. but I've not worked with powersports engines before. Tractor, heavy equip, and automotive is my experience. It does sound tinny.. like it's being reverberated out the exhaust..
This machine was bought new by my father in law to tour logging roads, etc. while camping.. It's not been used to tow, and not beaten, overheated, swamped, jumped, rolled, crashed, redlined, etc. Since there isn't contact with the piston and valves, I would assume I don't have a major timing chain issue..
What next? I'm out of ideas....
