A little history.... Have never had to work on this unit before other than normal maintenance, just over 9000 miles..(great machine) About 300 miles ago stopped having to push red button to put into reverse, it just sifts when I hit the button. (Electric Shift) About 100 miles ago the machine started to JUST Quit after it got good and warmed up (Suspect Coil) Just let it cool off for 10-15 minutes and fires right up and run again until good and warm. Discovered cooling fan has seized up (replaced) Same dying issue when warm. The other day Ran about 7 minutes down trail, stopped and idled about 1 minute. Hit throttle to leave,,, Unit Backfired and died. Would not restart, pulled home. Next day it started right up and ran good until I put it in gear. It died and wouldn't restart. 2 days later - repeat performance. Now won't start at all... Things checked.. It has spark, Fuel injector fires, fuel pump working. Valve clearance is good, Valves appear to move free when cranking. Good strong suction when I put hand over throttle body intake while cranking. Fuel injector only fires for the first couple of revolutions, then stops firing. Tried Starting fluid,, does not fire,,, double checked spark, still sparking. Any Ideas???
