Greetings I got almost brand new storage trx400 2007 engine is perfect condition, did carb rebuilt due to fuel leaking from float bowl, it stop the leak. Now it is hard to start the atv only will start on choke off and throttle, as soon as I let go of the throttle it dies. Air filter is new spark plug is new battery is new. Any help please thank you. I didn’t change air fuel screw since I don’t have the tool? Can that be a problem?
Okay I will check what about choke on it won’t turn on only does it on choke off and throttle push. How comes it not starting on choke up on when it’s cold engine thanks
Are you putting it on full choke or half? If I put mine on full choke it doesn’t usually start because it’s too much at times. But if I put it on half choke it’ll start every time.
I put it no choke down or sometimes half way it starts when I put it all the way up choke up it won’t start at all. Also I need to press throttle to keep it running as soon as I let go it shuts off thanks
Your other thread has more posts in it, so please continue the conversation there, and not in this thread.
