Hi everyone, I'm new here.
I picked up a 350hr 2007 Honda trx400 4x4. with a no start condition.
the dash lights up the starter turns over and it has good spark. put in a new NGK plug,
I cleaned the carb (twice now), flushed the tank, checked tank flow and still no start, it just spins over. It did backfire once (a little starter fluid)
I have ran the self diagnostic and came up with code 12 and 6. also the diff lock light flashes 6 times, then pause and repeats, I am not sure what that refers to.
Code 12 and 6- Following the troubleshooting guide in the manual it seams to point to the ecm being bad.
I have proper voltage at the ecm and continuity between the "natural" plug and ecm plug.
all buttons seem to work (kill switch, ecs/auto, level sensor). the ecm was very muddy, but the plug connections were clean, I am guessing the ecm took on water. Previous owner said he drove it into the his garage, and it never started again.
Before I order a new ECM (where is the best place to get one?) is there any other test I can run to make sure mine is bad. I am very surprised that with fuel and spark it will not attempt to start. nothing just spin, spin, spin.
I pulled the valve inspection covers, verified TDC and the valves are moving, I will pick up a feeler gauge today and check the valve lash.
Is there away to bypass or trick some of the sensors to verify start then ad them back one at a time?
Thanks for your help
MrC.
MrC.
