My electric starter works about 2/3's the time. If it doesn't kick in I can usually tap it with a hammer and it will turn over. When I pulled the starter it turns every time on the bench.... So I'm not confident it's a starter issue, or is it just that it needs to be under a load to fail. When it does fail on the bike I confirmed that it is getting voltage. Since I can tap it with a hammer and it works I'm fairly confident its the brushes in the starter motor but thought I'd check here first.
Other issue I have is motor oil dripping out the yoke boot on the rear output shaft. I assume this is due to a failure of the rear output shaft seal but wanted to ask and see if anyone else has had this issue before I tear the swing arm off to replace. I noticed where the engine breather presses up to the air filter in the air filter box there was a little lube on the filter, wondering if that was causing an air tight seal that was raising the engine pressure causing the oil to be forced out of the seals.
