1 - 9 of 9 Posts
I put on a aftermarket carb and didn’t adjust anything normally they work fine. This one upon start will idle for s second then rev up really high for a few seconds then back to idle and keeps repeating. Also the speedometer got some water in it and needs replacing would this make it cause that problem? TIA David
What ATV is it?
The main issue is the aftermarket carb, scrap it and buy a used known good OEM replacement and overhaul with an OEM or known good brand service kit such as shindy.
Reactions: Puddleduck62
learn how to rebuild one. and use a shindy kit. you will never regret it..
dont buy from china the best you can
1 - 9 of 9 Posts
