Hello All,
First post on the forum!
Looking for advice regarding the rear differential. I recently purchased this machine from a friend. The rear brakes were seized which I hear is common. I took it all apart a couple days ago and there was muddy water in the drum. The seals looks okay but were probably worn.
While I was working on the brakes I drained the rear diff (fluid thick / black but not muddy and no water). I refilled it, flushed and refilled again (slightly overfilled). I left it overnight and the excess leaked into the axle tube and drained out the brake side which was still dismantled.
Should I be concerned about the diff inside seal or is it normal for the excess to leak out (about 1 oz). I'd like to figure it out before reassembling the brakes if I need to do the diff seal. The outside seal looks fine and the oil wasn't too bad.
Also, for aftermarket what is the quality of Allballs vs OEM diff rebuild kits?
Ryan
Ryan
