I am new to the forum. Thanks for adding me.
I have a 2007 TRX 400 that is giving me headaches. It is In limp mode.
It's flashing #12 fault code, Shift control Motor and sometimes will blow the 30 amp fuse for the control motor. I have disconnected the motor and put 12V to it so it does turn . Checked plugs for corrosion. Checked battery connections. Now it will not shift with the electric shift and sputters in reverse. I had it running in the shop with the control motor off buy hooked up. I could here it running and even when I shut the key off... the control motor stayed running. I am also getting that dreaded electrical burn smell coming from the CDI box. The side of the box with the 5 wire plug gets dangerously hot and stinks. I am thinking I have a BAD CDI but hate to buy a new one if somthing else is shorted out. I am going to download the manual and go from there. I was wondering if anyone has had the same issues.....
No shift.
Limp mode.
Sometimes blows 30 amp control motor fuse.
Any help would be greatly appreciated.
Thanks
Mark
No shift.
Limp mode.
Thanks
Mark
