1 - 1 of 1 Posts
I have a 2007 honda rincon 250 when I first got the quad it would start in gear by pulling it or knocking it in gear moving. I changed the solenoid and the fuse battery too still no fire off the solenoid or switch so then I start checking for loose grounds sure enough on the back of the block is a ground off the back just hanging its in the same area of where a pull string would attach but mine lacks the pull start case so I'm not sure if it has anything to do with the problem but it got caught in the crank and frayed it to dark to chase it tonight anybody know what it grounds
1 - 1 of 1 Posts
