Good evening, I have a 2007 Honda Rancher 420 2wd Manual Shift. To start from the beginning, battery died, tried to charge it, it started, shut off now will not do any thing. It keeps blowing the 10A IGN Fuse and Fuel Pump will not run like normal when the key is turned to the on position. I have pulled all of the electrical connections in the back of the bike and plugged in until the fuse blows. Originally, i found that when i plug the relay that is in the back into its connection, it immediately blows the fuse. I thought it was the relay, ordered another, and same issue continues. When the relay is not plugged in, the bike will turn over all day long, (Still nothing from the fuel pump and will not start, just turns over) with all of the connections connected or disconnected, except for the starter solenoid of course. When i plug that relay in, if all connections are connected it will blow the fuse. If the right one is plugged in (grey) and the left one unplugged (Black Square) (At the back of the bike facing forwards) the relay makes a buzzing noise. Also noticed today, with all of the electrical connections together, the right plug (grey) (at the back of the bike facing forward) the wires going get hot to the touch. Any help would be much appreciated.
