My bike is a foot shifter only and the other day I was riding and it just stopped moving completely in first gear so I went through all of my gears and nothing would get it to move at all so I drug it home pulled the front case cover off and the clutch plates are still together and there is no play in them so I’m not sure what to do to fix this shifting problem
OK what oil have you been using in the atv,a s if you were NOT using wet clutch approved oil the clutch plate can stuck together and get ruined!
and do the wheel turn when in N, or are things still locked up?
as mrb asked ^^, what oil are you using in the motor ?. have you inspected the drive line to see if the transmission is even going in gear ?. jack it up ( all 4 wheels must be off the ground ), put it in 1st gear, spin the rear wheel, does it feel like its catching ?. if not ?, then you have drive line issue. if it does catch ?, then you have a clutch issue :).
Thank y’all very much I got it off the ground and the back tires caught going forwards and wouldn’t spin and I just got the bike so I bought some 10w30 for it but haven’t put the new oil in it yet bc of the front case being off should I be using a different oil? And I am about to be taking the clutch off to replace the plates I guess
is that 10w-30 oil made for wet clutches ?, if not ?, do not use it !.
this tells me you have clutch issues ^^^, have you tried adjusting the clutch yet ??.
