I was riding my wheeler yesterday just bought it and it ran perfect a bunch of times and just went through all the gears and was down shifting it is the es and i stopped it in 2nd and it wouldn't shift down anymore but went up. So I turned it off manually pushed it back into neutral and it would go into all the gears up just not down so I had to
Manually do it again and now it stopped shifting at all. So I change the angle sensor nothing changed .... so I pulled the shift motor and then check the shift gear and it was missing teeth so I changed that now it's shifting again just not engaging into the gears I can hear it shift and it's giving off code 22 I'm pretty sure I checked all of the connections and it's still doing it I HAVE NO IDEA WHAT TO DO !!!
