I bought a 420 rancher a few weeks ago not running. The guy said it ran when it was parked but had been sitting for years. So I cleaned the entire fuel system on it new battery new plug and it wouldn't start. So I put some gas in a spray bottle sprayed it in the throttle body and it will fire right up no problem. Since then I have installed new fuel pump and new injector and it still won't start unless I mist gas in the throttle body. It's getting power to the injector also. So I'm puzzled on why it's still not getting fuel unless the throttle body is plugged where the injector goes in. Thanks
welcome to the forums. sounds to me the injector is clogged/dirty :).
Are you getting plenty of fuel at the injector?
Yeah it gets plenty of fuel to the injector. And it's all new unless the new injector is already plugged?
Did you clean the tank on it? It’s all fresh gas going through it? The fuel pump was replaced so obviously that external bowl or whatever was cleaned too?
