thanks but i have the honda shop manual , but what im asking is when i put the manual select for 4x4 everything seems to shift externally , but does not engage the front diff. has anybody had this problem , or is there any suggestion on what to do or could be wrong ???? thanks
i don't know alot about the es models..but..from what your saying..it sounds to me like some kind of elec switch thats connected to the front drive shaft isn't working..and engaging the front differental..seems like it to me anyway. you didn't strip out your front differental's ring and pinion gear's did you ?..any noise ?.like grinding.. thunking ?..if thats ok...it's probally some kind of elec switch or sensor..would be my guess.
The 420 uses a cable to engage/disengage the front diff, maybe the cable is out of adjustment.
