Hey, I pulled my engine to replace the starter clutch, everything went smoothly, engine back in, connected everything up and it won't start...
When I turn the key you can hear the fuel pump etc.. but when I press the start button there is nothing. The display is also showing the little bar instead of N, it isn't flashing, just stays on and it won't select any gears. Tried the manual lever and it will go up and down the gears but nothing on the buttons.
If i pull the front brake it and press the start button, it will churn but won't start.
Pulled the plug and it has a good spark but it's dry....
Are these problems related or have I 2 separate issues here... bike was fine apart from starter clutch...
Help please...
Help please...
