Was riding in 5th gear and it was like the rear end locked up. Got it home and used a 8mm wrench to get it into neutral now it will shift up and down but every gear is reverse. Reverse works perfect. But neutral is reverse also. And when I put it in first it wants to go backwards like it’s in reverse but it’s in a bind. Shift motor works fine and engine runs perfect. I just need to know if it’s something simple I’m over looking or if it’s in my transmission gears. Thanks.
If the gear indicator changes gear numbers when you shift, but the transmission stays in reverse, then you will have to rebuild the transmission.
