I am new to the forum, and need some help. I have 2007 Honda 420 w/elec. shift. It has 5000 miles on it.
:yeahbaby01: UPDATE Fixed problem, removed front case and found the gear shift cam was loose. Center bolt had worked its way out against the spring. Took it apart, cleaned, then re- assembled it, this time putting Loctite on the bolt. Put all back together. and everything is fine and shifting again.
I am not a mechanic, but a technician, who finds the problem.
Thanks to all!
Thanks to all!
